Automotive and Embedded Networks
Controlling CANoe TestCases in LabVIEW over ActiveX
I want to run CANoe TestCases in LabVIEW using ActiveX.
Handling envVars and sysVars in CANoe was not a big deal and there are a lot of examples here.
But handling TestCases is quite difficult. The CANoe help file shows this way in the object hierarchy:
Application
Configuration
TestSetup
TestEnvironments
TestEnvironment
TestModules
TSTestModule
TestSequence
TestCase
But I didn't find any way to realize it. I ended up in the following:
IApplication3
IConfiguration4
ITestSetup
ITestEnvironments
ITestEnvironment
ITestSetupItems
ITestSetupItem
 ITestSetupItem is an object without any methods. I don't know how to access the TestCases without the linking objects in between.
Greetings,
Ludwig.
(8,148 Views)
Accepted by topic author Ludwig72
I've solved the problem with the help of Vector Support. They send me the following C# Example:
            CANoe.Application mApp = new CANoe.Application();
            CANoe.Configuration mConf = (CANoe.Configuration)mApp.Configuration;
            CANoe.TestSetup mTestSetup = (CANoe.TestSetup)mConf.TestSetup; //Test SetUp Window
            CANoe.TestEnvironments mTestEnvs = (CANoe.TestEnvironments)mTestSetup.TestEnvironments;
            CANoe.TestEnvironment mTestEnv = (CANoe.TestEnvironment)mTestEnvs[1]; // Test Environment (*.tse File)
            Console.WriteLine("Name " + mTestEnv.Name);
            CANoe.TestSetupFolders mTestSetupFolders = (CANoe.TestSetupFolders)mTestEnv.Folders;
            CANoe.TSTestModule mTSTestmodule = (CANoe.TSTestModule)mTestEnv.TestModules[1];
            Console.WriteLine("Name " + mTSTestmodule.Name);
            CANoe.TestSequence mTestSequence = (CANoe.TestSequence)mTSTestmodule.Sequence;
            Console.WriteLine("TestSequence Count " + mTestSequence.Count);
            CANoe.TestCase mTestCase = (CANoe.TestCase)mTestSequence[1];
            Console.WriteLine("Testcase Name " + mTestCase.Name);
            mTestCase.Enabled = false; // deactivate testcase - XML and structured NET module only.
            //CANoe.TestReport mTestReport =(CANoe.TestReport) mTSTestmodule.Report; // Access To report
            CANoe.Measurement mMeasurement = (CANoe.Measurement)mApp.Measurement;
            if (!mMeasurement.Running)
                mMeasurement.Start();
            mTSTestmodule.Start();
 I've realized that you can cast ActiveX object references to another child class in the following way:
This was the correct solution and I want to share it with you.
(7,909 Views)
Hello Ludwig72,
I know this post is very old but i'm very new to active X with LabVIEW. Can you please share me some sample code.It will be so helpful.
(3,430 Views)
@sunny7569650 wrote:
Hello Ludwig72,
Here you are:
(3,411 Views)
Thank You @Ludwig72
(3,403 Views)
