I need to generate a burst rate of 30 frames back to back with a 3 bit gap in between. I am using a baud rate of 500 kBaud.
To do this, I think I need to configure the baud rate using the timing registers. I noticed that in Measument & Automation Explorer I can adjust the parameters: prescalar, jump width, time before/after sample and sampling mode and view their effect on the registers. I have been unable to find out what these parameters are for or how I should use them to solve my problem. Can these parameters be used to set the gap to 3 bits?
