02-22-2005 05:10 PM
03-17-2005 03:54 PM
03-17-2005 04:19 PM
first I would reference a Knowledgebase record that describes Explicit
Messaging; G16551 - DeviceNet Basics of Explicit Messaging. Knowledgebase is a database of application notes and technical
information on Rockwell products. A link for Knowledgebase can be found
on the Rockwell Support website: http://support.rockwellautomation.com
The following is an excerpt of an EDS file for an AB 160 drive which
happens to be commented to include information on the different entries.
Be aware that not all parameters can be written too but most if not all
parameters can be read.
Param30= $ parameter instance
0, $ data slot - don't care
6, "20 2A 24 01 30 69", $ path size, logical address
(class, instance, attribute)
0x0030, $ descriptor - in hex format
2, $ data type (UINT)
2, $ data size
"Bus Voltage", $ name
"V", $ units
"", $ user manual reference page
0, 800, 0, $ min, max, default data values
1, 1, 1, 0, $ mult, div, base, offset scaling
0, 0, 0, 0, $ mult, div, base, offset links
not used
0; $ decimal places
As you can see in the comments the line: 6, "20 2A 24 01 30 69";
is the path of the parameter which includes the Class, Instance, and
Attribute information which is necessary for the explicit message.
To read this parameter one would use the get attribute single command 0x0e
with Class 0x2A instance 0x01 attribute 0x69
03-17-2005 04:19 PM
07-07-2005 02:24 AM
07-07-2005 01:09 PM
