01-11-2017 05:06 PM
Hello, I want to use the XNET Bus Monitor to transmit a message, but the Measurement menu doesn't contain the item "Transmit Frame" like the documentation says it should. I know it works only for CAN, but I do have CAN, the interface is called CAN1...
What do I need to do?
Solved! Go to Solution.
01-12-2017 07:49 AM
What version of XNET are you using? In the most rescent version (16.1) the functionality in quesiton has been moved to a tab labeled Transmit.
01-12-2017 10:28 AM - edited 01-12-2017 10:29 AM
I'm using 15.3.
Edit: OK I just realized that 15.3 also has that Transmit tab!!
