01-24-2012 10:39 AM
As the Subject Title suggests, can the NI USB-8451 or NI USB-8452 be configured as an I2C SLAVE?
Has anyone done this successfully, is it likely to be possible?
We have a test subject which operates as an I2C master, we would like to emulate the complete system by connecting a slave to the test subject whose response is programmable.
Wondering if either of these NI units would be suitable.
Alan
01-24-2012 11:18 AM
This is not a feature that is currently supported by the NI USB-8451 or NI USB-8452. We are looking into adding this functionality to the NI USB-8452 but we cannot provide any status or timelines. However, if you are willing to post more information about your application and timeline requirements, we will certainly take your information into consideration.
01-26-2012 01:15 AM - last edited on 01-26-2024 05:08 PM by migration-bot
Will a non OEM version of the NI USB-8452 be produced ? The max I2C clock rate (250kHz) of the NI USB-8451 is too low for some of our applications, leading us to buy third-party interfaces.
02-02-2012 04:43 AM
Thanks for your response. We will probably be working around this by hosting several slave devices in the Test Equipment, and switching the I2C bus (using relays) between the NI-8451 (part of the Test Equipment) and the UUT.
09-12-2012 08:02 AM - last edited on 01-26-2024 05:09 PM by migration-bot
There is now an NI I2C slave device: NI USB-8452 as of August 2012 (NI-845x 2.1 driver)
09-13-2012 04:33 AM
Please let us know when it will be available.
12-04-2012 09:09 AM - last edited on 01-26-2024 05:09 PM by migration-bot
Better late than never... Retail (Non-OEM) NI USB-8452
12-05-2012 12:04 PM
Thank you for this long awaited information.
05-06-2013 02:28 PM - edited 05-06-2013 02:29 PM
Can the 8452 be configured as a I2C slave?'
Nevermind. I just read the manual. It looks like it can. Thanks.
05-06-2013 02:30 PM
Yes. The USB-8452 can be used as an I2C Slave.
