Hi!
Did someone find a suitable answer to above query?
I have a similar issue.
We want to deliver LabVIEW code which will run only on licensed machines.
One idea is to build in the MAC address of these machines into my code and check everytime the software is run. Question is how do I retrieve the MAC address of the ethernet card at run time in my LV exe?
Is there another way to achieve a node locked licensing? Some people use HDD serial number ....
Suggestions are welcome.
Thanks.
- Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
