I think you do not understand CAN correctly here, you are using 1 port to both Send and Receive CAN frames. CAN works by sending and receiving data over the same 2 physical wires, so the CAN chip can not physically send a message at the exact instant it is receiving a message (this is a limitation of ALL CAN chips, it was intentionally designed this way).
This VI is the closest you will come, with the example you are able to switch between sending and receving CAN traffic on one port with almost no delay.
One other note, because you are using the same configuration for both sending and receiving, the CAN chip will be configured to read any CAN traffic and put it into a buffer whenever it is not actually sending a message, so you are not missing messages, you just nead to issue a CAN read command to get the messages in the buffer.
Hope this helps
