06-20-2007 05:03 AM
06-21-2007 04:13 PM
06-22-2007 11:36 AM
11-26-2013 07:29 AM
If we dont want to use ECU measurement and calibration toolkit, is there any way to control CANAPE from LABVIEW?
Is there a way to read/ write ECU parameters from LABVIEW through CANAPE? Any .dll?
03-06-2014 03:39 AM
my question would be:
how can i programaticly load a CANape measure configuration with definded signals?
I want control CANape with Labview.
I can add a signal with CalibrationObjects invoke node, and then i can read or write the signal
, but i need to define a measurement with many signals in it.
i dind`t find a appropriate ActiveX node to add measurement signals to the measurement,
and if i try start the measuere, then i get the error message from CANape,
that no signals are defined.
i thought, it would be also a possibility, if i define the measure signals in CANape before start
the automation, and save it in CANape measurement configation (.cna) file.
But if i try to load .cna file with invoke node Application2/ method loadCNAfile
then i get the error message, that CANape is not in the right mode to do this.
any help and hints are welcome:)
thank you,
best regards
Robert
11-10-2014 08:24 AM
Hi Robert,
Now I am in the same situation that CANApe has to be driven from LabVIEW. I want to write a particular variable by accessing its memory via CANApe. Could you please guide me in this to control CANApe using LabVIEW
Thanks In Advance,
Ragupathi C
