Automotive and Embedded Networks
CAN write/read program
I need help making a program that programmatically writes and reads the CAN bus in sequence. I need to write frames to the bus then read the bus sequencially and also multiple times. I keep getting errors in the write.vi. The error is BFF62125. I need to write a message, receive the response, and write another message and receive the response. Also I need the program to execute so that when I run it automatically performs all the tasks in order then ends.
(3,312 Views)
Hi Phil:
Here is some example code from the NI website that should get you on your way.
CAN Send and Receive using NI-CAN Frames
Emilie S.
(3,287 Views)
