05-03-2012 10:42 AM
I have an application that has been running fine for months, but today I am getting the CAN 1073094699 warning. None of the hardware or cabling has changed. The app is written in LabVIEW. I can't see any software issue that would cause the problem either.
I found this thread: http://forums.ni.com/t5/Automotive-and-Embedded-Networks/CAN-HARDWARE/m-p/174345/highlight/true#M101...
, but it wasn't helpful.
I am opening the NI CAN device, communicating with one CAN instrument and then closing the CAN device. I am getting the error after starting/stopping communication with the device during the testing.
Any suggestions?
05-03-2012 11:17 AM
Some basic info please, such as Baud Rate, Hardware, cable lengths, how things are terminated, cable topography, possible noise sources..
05-03-2012 04:05 PM
Baudrate: 500000
NI USB-8473 CAN interface
NI CAN cable 192017-02, cable connects directly from interface to CAN device. I need to double-check the termination at the other end.
11-07-2013 10:08 AM
Great answer to the question.
Wait, there was no answer to this question... 😞
11-08-2013 07:27 AM
I never really found a fix to the root problem. I was able to mitigate the issue by doing a CAN reset.
