NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
vt92
CAN warning 1073094699
I have an application that has been running fine for months, but today I am getting the CAN 1073094699 warning. None of the hardware or cabling has changed.  The app is written in LabVIEW.  I can't see any software issue that would cause the problem either.
I found this thread: http://forums.ni.com/t5/Automotive-and-Embedded-Networks/CAN-HARDWARE/m-p/174345/highlight/true#M101...
, but it wasn't helpful.
I am opening the NI CAN device, communicating with one CAN instrument and then closing the CAN device.  I am getting the error after starting/stopping communication with the device during the testing.
Any suggestions?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Active Participant
GPIB_Guru
Re: CAN warning 1073094699
Some basic info please, such as Baud Rate, Hardware, cable lengths, how things are terminated, cable topography, possible noise sources..
Active Participant
vt92
Baudrate: 500000
NI USB-8473 CAN interface
NI CAN cable 192017-02, cable connects directly from interface to CAN device.  I need to double-check the termination at the other end.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
