I have programmed my CCP application, which communicates with an ECU for the purpose of setting up data acquisition and calibration. This all works well.
In conjunction with this, I have created a user interface vi., which is about 20Meg in size (I know is to large but theres no other way). Both these vi's run simultaneously.
I have a CAN read function which I call every 5ms within a while loop. I am reading 1 sample at a time because without a timestamp on my data acquisition, Im using local loop time to determine time between messages. All this works fine and the 5ms read is a more than sufficient read rate, however after running this for a period of several minutes, the system begins to slow giving:
1) Samples pending flutters off zero and slowly begins to increase.
2) Loop time of 5ms cannot be maintained which is why the above happens.
3) When samples pending reaches a high enough value, the buffers are full and i get an error.
If I close my whole labview application down and restart, it is then ok.
I am quite confident that my application is pretty efficient and no while loops are "hogging" any time. I monitor all while loops and loop timing to ensure this. I am trying to reduce Windows processes to help solve this.
Is Labview using significant resources somewhere, which arent being cleared, thus giving me this error after a certain period?
