05-28-2015 08:04 AM - edited 05-28-2015 08:04 AM
I can release a version 4 where unique names are used, so that multiple sessions can be opened at once. I would just like to make sure it works before I release a new version. Attached is a zip with two mods should work. The first is the new Get Alias from DBC which generates a unique name. The next is the new Close Connection which will try to cleanup any databases that don't exist anymore. My worry was you'd end up with 100s of randomly generated database names and only a few would be used.
Use these VIs in replace of the onces from the version 3 and if it works I can release it as version 4.
EDIT: Or another option for you is to combine those two DBCs into one.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-28-2015 08:22 AM
Yes, I could do that, but the other dbc file is still in production (for battery monitoring ) and I think it would be better to check this option first. I'm just missing some library for OpenG, just installing it right now, I will give you feedback as soon as possible.
05-28-2015 08:27 AM
Yeah sorry I didn't realize the OpenG File I/O dependency wasn't there. Because of some VIPM changes I don't want to add that dependency to the API. So in the actual Version 4 (assuming this works) I'll remove the need for the OpenG File library.
05-28-2015 08:35 AM
Yes it really does the job 🙂 Thanks man, this really great piece of software
06-17-2015 07:07 AM
Can you help me to find out the 8 byte data in pay load..?
06-17-2015 07:22 AM
Can you help me get more information? You are showing one signal in the frame. What does the rest of the frame look like? What are the values of the signals? This library is designed to tell you what the 8 bytes of data are for the signals, you don't need to do any manual math.
06-17-2015 11:38 PM
Thanks for reply
Actually need to extract my dbc file, from that i want Arbitration id and pay load for each signal.
Arbitration Id: 280 PayLoad: 0 0 0 20 0 0 0 0
06-18-2015 06:55 AM
Is English not a language you are comfortable with? Your request is not clear, and your information is lacking. Attach your database as XML or DBC, then attatch your data either frames, or signals. Using this API it is very easy to go from one format to the other, with example help files, and detailed help in the VI functions. If you cannot follow instructions, or answer questions, then I cannot help you.
01-28-2021 11:34 AM
Great library! It has been very useful. Thank you.
The Frame to Signal conversion does not seem to take into account the Data Type from the database. So does it handle both signed and unsigned integers properly or does it only work with unsigned int?
01-28-2021 12:13 PM
I'm not sure I understand what you are saying. Could you post an example frame with what you expect the conversion to be and see how it differs from the library? Also I hope you are using the latest version which right now is version 8 posted here. I have another version planned which is almost ready for release and supports CAN-FD but I'll hold off if you think there is a bug that could be fixed first. Its true that I don't take into account the data type of the signal. It just applies the offset and scaling as provided and returns a double.
