I'm trying to use the NI Visual Basic test sample program Single Sample Output.vbp installed from the CAN CD, directory "MS Visual Basic\Channel API examples\Single Sample Output".
When running on the controller with the CAN card (self test all right), I get the error BFF62201 from the function nctInitStart with text: "Error 0xbff62201 (nctErrUndefinedChannel); Channel not found in MAX or the CAN database file. Solutions: Check for proper spelling using MAX; For Get/Set Property, ensure that the channel name exists in the task."
What can be the problem / solution ?
With thanks,
best regards,
Geert
