08-11-2014 09:17 AM
I'm looking into interfacing with a DUT that has Ethernet Audio Video Bridging (AVB). A protocol similar to Ethernet which is used for in vehicle audio and video transmission. To test this interface I just need to provide a static image and then ask the DUT if everything is okay. The actual vision analysis is a seperate test.
Has anyone done anything with AVB testing? It appears to be an obstraction layer on top of UDP so I suspect if nothing else I can do low level UDP calls but I don't really know what I can or can't do. Any help is appreicated, thanks.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
08-12-2014 08:14 AM
Hi Hooovahh,
I've done some research in our internal systems and have not found any references to AVB. I think we'll need to see if anyone else in the community has done something similar. It also appears that AVB was renamed to "Time-Sensitive Networking" in November 2012.
If it is based on UDP, you should be able to use the lower-level UDP functions in LabVIEW to do the communication.
Best Regards,
01-12-2015 05:40 PM
Dear All
I am really want to learn about AVB. I have lot of doubt about avb. Is there any forum available to get help from. I am really stuck with the FQTSS. Your help is highly apreciated.
Thank you
01-13-2015 05:15 PM
There is not a dedicated NI forum for AVB. I have searched around online and could not find an AVB specific forum. Hopefully another community member has suggestions on an AVB forum!
08-05-2015 02:50 PM
The AVnu alliance will be a good strating point: avnu.org. We are developing some solutions at my company so please feel free to contact me at thierryr@danlawinc.com
