Audio Video Bridging
I'm looking into interfacing with a DUT that has Ethernet Audio Video Bridging (AVB).  A protocol similar to Ethernet which is used for in vehicle audio and video transmission.  To test this interface I just need to provide a static image and then ask the DUT if everything is okay.  The actual vision analysis is a seperate test.
Has anyone done anything with AVB testing?  It appears to be an obstraction layer on top of UDP so I suspect if nothing else I can do low level UDP calls but I don't really know what I can or can't do.  Any help is appreicated, thanks.
(6,981 Views)
Hi Hooovahh,
I've done some research in our internal systems and have not found any references to AVB. I think we'll need to see if anyone else in the community has done something similar. It also appears that AVB was renamed to "Time-Sensitive Networking" in November 2012.
If it is based on UDP, you should be able to use the lower-level UDP functions in LabVIEW to do the communication.
Best Regards,
Matthew B.
Offering Manager
NI
(6,964 Views)
Dear All
  I am really want to learn about AVB. I have lot of doubt about avb. Is there any forum available to get help from. I am really stuck with the FQTSS. Your help is highly apreciated.
Thank you
(6,310 Views)
There is not a dedicated NI forum for AVB.  I have searched around online and could not find an AVB specific forum.  Hopefully another community member has suggestions on an AVB forum!
(6,292 Views)
The AVnu alliance will be a good strating point: avnu.org. We are developing some solutions at my company so please feel free to contact me at thierryr@danlawinc.com
(5,648 Views)
