Error:
NI-XNET: (Hex 0xBFF63166) You used an empty name for the XNET Session. Empty name is not supported. Solution: Use a valid XNET session name from your LabVIEW project
when I create my session I've selected the signals in which go to the session based off the database file I will send it. when the session gets sent to my create I suddenly get an session name empty error
I can see that on my session value I have:
___xnetSesn#00000002
in that IO value should I instead have the signal names? I thought the above was my session name
