01-29-2013 09:58 AM
I'm using Automotive Diagnostic Command Set with LabView to read parameters from ECU, that works on FORD EDGE AND HYUNDAI SONATA, But It did not work on HONDA Accord, there is no feedback from ECU.
Does the setting such as Baudrate, Trainsmit ID and Receive ID on Accord are different from others?
Does anybody give me a help?
Thank You
GQ
01-30-2013 11:29 AM
Hi GQ,
What year Honda Accord are you working with?
What type of OPC ISO are you using to connect to it?
I'm not sure about the settings for the Accord, you might need to get in touch with Honda for that information.
01-30-2013 11:53 AM
Hi Andrew,
Here is the answer:
What year Honda Accord are you working with? 2012
What type of OPC ISO are you using to connect to it? ISO TP-Normal Mode
All settings are same as those in example from National Instrument.
Guoqiang Li
01-30-2013 12:30 PM
Hi GQ,
Its possible that those settings will need to be changed from their defaults for interfacing with Honda's ECU. You will need to talk to Honda about what those values need to be set to though, we do not have access to that information here.
04-10-2015 07:36 AM
Is the above issue resolved?
If yes, please share the solution to this problem as I am facing the same problem.
I am receiving CAN data at rate of 500K using CAN Receive.vi in Example Finder but I am not getting any feedback from ECU when I use Automtive Diagnostic Toolkit.
Adnan
