07-22-2016 07:58 AM
I want to use a NI9881 CAN module which requires an additional power supply (Vsup pin of the DB9).
Moreover i have a CAN power cable with a positive and a negative terminal in addition to the DB9.
Are this positive and negative terminal, pins for the power supply, or do i have to connect directly the Vsup pin ?
Thank you !
Solved! Go to Solution.
07-27-2016 01:48 PM - last edited on 01-25-2024 04:50 PM by migration-bot
If you have a NI power cable such as this one: CAN Cables with Power Terminal
Then the + terminal on the cable is tied to Pin 9 and Vsup.
The - terminal will be tied to Gnd.
07-27-2016 02:39 PM - edited 07-27-2016 02:39 PM
The NI CAN Breakout Box is kinda nice in these situations. It might seem expensive for what is mostly a DB-9 break out, but it has screw terminals for power input, and a DC barrel plug which make powering a CAN bus easier, along with switches for various resistor termination.
http://digital.ni.com/public.nsf/allkb/D3AD3B86FC3A52A386257B2700530419
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-28-2016 08:18 AM
Thanks a lot ! It's ok 🙂
