Additional NI Software Idea Exchange
ClaudioH
VeriStand Hardware configuration import from MAX
Status: New
Today we need to configure the hardware in MAX and in System Explorer.
Allow VS to import the hardware configuration from MAX and eliminate the DIO number of ports and port size manual definition.
I guessed the PXI2569 and PXI2570 configuration in a trial and fail matter till I found the number that did not cause an error during deploy.
Import all board I/O configuration and let the user remove what is unused later.
Cheers,
CHCastro
CHCastro
1 Comment
NAKeel
Member
Starting in NI VeriStand 2012, NI VeriStand includeds a Hardware Discovery Wizard that makes it easier to import hardware.  While it does not import Max Definitions, it should make hardware setup much easier.  Does this help?
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
