Additional NI Software Idea Exchange
RyanWright
Support Switch Executive virtual devices in the MAX configuration import, export wizards (System Configuration API).
Status: New
Currently, Switch Executive virtual devices can only be imported and exported through Switch Executive itself.  It would be really nice if instead Switch Executive virtual devices were handled through the MAX configuration import and export wizards.  This would simplify test system deployment, particularly since the MAX configuration import wizard can be easily automated through deployment installers.  Importing of Switch Executive devices can currently be automated, but you have to create an executable using the Switch Executive Configuration API and then call that executable using a batch file called by your deployment installer.  It would be so much simpler and more consistent if the MAX configuration wizards supported Switch Executive in addition to other products such as DAQmx and VISA.
