Today I have a need that is a bit difficult to perform: I developped a soft that convert a xml file into a VI, but I'd like this soft to create a VeriStand model from this VI.
So it would be very interesting to be able to dynamically create a Veristand model in Labview, wheter thanks to an API or an invoke node, ...
I appears that for the moment the only way to do it would be to open the LVSV Dialog.vi by script.
If you look in the LLB that contains the LVSV Dialog.vi (look in <LabVIEW>/project/NI VeriStand/,) you will find a vi called "LVSV Batch Build.vi". This VI performs the same build that the dialog does, but does so programmatically.
I have been trying "LVSV Batch Build.vi" in LabVIEW 2012 with Veristand 2012, and it does not work. It errors out with a reference type mismatch error.
