If your project performs data acquisition of channels as Waveform data type(instead of single point), you can't associate this channel to a Aliases. Since the waveform data type receives a buffer of data, you could choose some common options for that channels, such as max buffer value, mean among others.
Since it does not exist, I had to create an workaround by acquiring data as single point and logged them using embedded data logger, then had to use Diadem to create the waveform channel.
In addition, it would also allow to acquire data in higher rates because the waveform acquisition loop runs ins parallel to the PCL.
This feature would be extrememly handy for those who are using waveform acquisition and logging, and would save me some months of work.
