In LV2014, making an lvlibp from AF is a snap. But the standard actor message maker doesn't work on Actors that inherit from Actor framework.lvlibp. Here is the Plugin Actor Message Maker.
To use:
1. Unzip into <LabVIEW>\project.
2. Open the project file (Plugin Message Maker.lvproj). It will ask you where is Actor Framework.lvlibp. Direct to your packed actor framework.lvlibp.
3. Save the project.
4. Close and open LV2014. You should see in Tools->Plugin Actor Message Maker.
Once you have loaded the project once, you can erase the project file (Plugin Message Maker.lvproj).
Note: If anyone has any suggestions how to make this into a VIP file, they would be welcome (to include the actor framework.lvlibp?To where to install it?)
