Academics Discussions
Reply
J1939 Example code Request
Go to Solution
Highlighted
Dear all
  This is venkateswaran from Coimbatore and I am working with LabVIEW in Industrial Automation domain.Now I am working with J1939 based UUT .In my setup I am using NI PXI 8513 High Speed CAN. UUT Specifications shown some PGN Numbers and SPN Numbers in funtionality so i want to simulate these signal with NI Hardware.So I need some examples to simulate
Venkateswaran V
Message 1 of 7 (1,631 Views)
Reply
Re: J1939 Example code Request
Dear Venki,
As far as I have understood is you are trying to connect an can to J1939 based connector in UUT, in this case you can simply make a connector module and start working on it.
Message 2 of 7 (519 Views)
             No ganesh i talking about programming , Specs given by the customer having PGN number and SPN number only but VI given by NI having only ID and Source address.So I want to know how to use the VI given by NI with my avilable informations.
Message 3 of 7 (519 Views)
Reply
Hi venkatesh,
Did you had a chance to check this and try?
http://www.ni.com/example/31215/en/
Message 4 of 7 (519 Views)
Ya i already read this white paper , this white paper shows transport and data link layer but i am having doubts on Application layer.In NI example shows below,NI Example.JPG
But in my case my specs having PGN number and SPN number for telltale operation.So i want to know that how i can interpolate PGN and SPN with this VI.Specs below
thank you
Message 5 of 7 (519 Views)
Reply
‎07-25-2014 01:24 AM
In this case take PGN as a Identifier and SPN as the data field.
Message 6 of 7 (519 Views)
Reply
But ganesh they give some ID and Condition for each SPN like 00-ON and 11-Error where i suppose to give this bit level information and ID in the message format.If you have any example kindly send to me.Can i have yours mobile number.You told me to insert PGN in ID field and SPN number is particular data byte(SPN is 21 means i suppose choose 21th byte of data field and insert the condition data to that field).
Thanks for yours Support
Message 7 of 7 (519 Views)
Reply
