I am using a pressure transducer px309 and I am not sure what terminal configuration to use since I have it connected the ground to the negative and white to the positive of the Daq, and also have the negative into a power supply along with the positive.Thanks in advanced.
Also what is the signal output for pressure units (e.g. psi or bar)
