NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Fer Fer
mydaq y multisim
Para usar la mydaq con multisim para mediciones en tiempo real, ¿se debe "dibujar" el circuito en multisim o sólo utilizaria las herramientas que multisim ofrece para poder vidualizar las mediciones?
Member
Fer Fer
Re: mydaq y multisim
The question in English is:
To use the mydaq with multisim to real-time measurements, is it necessary to "draw"the circuit in multisim or only use the tools multisim offers to display themeasurements?
Active Participant
Fernando_D
Hola,
Puedes simplemente utilizar los intrumentos de NI ELVISmx dentro de Multisim para realizar mediciones del circuito real, sin embargo, si quieres comparar resultados reales vs. la simulación, entonces debes también capturar el circuito en Multisim.
Saludos,
Fernando D.
Member
ramtok2
Active Participant
Fernando_D
Here it is:
If you want to take measurements from a real circuit you can simply use the NI ELVISmx instruments in Multisim, however, if you want to compare real vs. simulated results you must capture the circuit in Multisim (File>>NI myDAQ Design).
Fernando D.
Member SIQ
Member
SIQ
NI myDAQ Design ?
Buon giorno e ciao a tutti, avrei un problema con multisim un po oscuro, volevo sapere dove trovare la voce NI myDAQ Design, nel menù questa voce non esiste, sapete risolvere questa problema, la mia versione di Multisim e la 12
Active Participant
lfelias
Re: NI myDAQ Design ?
Hola SIQ,
Lo siento, no hablo italiano, pero te recomiendo publicar tu foro en la siguiente página: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
Ciao SIQ,
Mi dispiace, non parlo italiano, ma vi consiglio di inviare il vostro forum alla pagina seguente: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
Hi SIQ,
I am sorry I don´t speak italian; however, you can post your forum question in the next link: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
Luis Fernando
National Instruments Cono Sur
Ingeniería de Campo y Consultoría
http://chile.ni.com/
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
