Hi vielka.
First of all, I'd like to confirm if you're using the ELVIS or the ELVIS II board. Also, when you say "no leds activated" you mean the status leds?
If that's the case and you saw humidity in some pins the device is probably damaged and will need to be sent for repairs. You can make additional troubleshooting steps, I'd recommend you to:
1. Verify that the power source is giving the appropriate voltage.
2. Check the fuse for continuity to make sure it's working.
Aldo H
Ingenieria de Aplicaciones
