NI Home
Cart Cart | Help
You are here:
Reply
Member
ellisemuhire@gmail.com
Accepted Solution
NI DAQ CARD FORSCANNING PV MODULES WITH 10mA lIGHT SOURCE
WHICH TYPE OF NI DAQ USB CARD FOR SCANNING PV MODULES WITH 10mA lIGHT SOURCE AND WHICH SENSORS CAN BE USED?
THANKS!
Member
JaredRo
Re: NI DAQ CARD FORSCANNING PV MODULES WITH 10mA lIGHT SOURCE
Hi ellisemuhire,
If you can provide details about what type of functionality you need (analog input/output, digital input/output, etc.) and some details about the signals you'll be working with I can recommend a USB DAQ product for you.  We have a wide range of products so I will need some more information to make sure I make the best recommendation for you.
Jared R.
Precision DC Product Support Engineer
Member
I NEED IT FOR ANALOG INPUT
Member
JaredRo
ellisemuhire,
How many analog voltage input channels will you need to read?  What is the range of the signal you will be reading?  How frequently will you need to sample the input signal?  How many bits of resolution do you require?  We have USB options that can read analog voltage with 12, 14, and 16 bits of resolution.
Here is a link to our USB Multifunction DAQ cards.  I can make a suggestion for you if you have these details.
Jared R.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
