NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
WhiteCloud
Accepted Solution
Maximum frequency for the Digital Counter Input
Hi everybody,
for measuring the speed of a rotating wheel, we drilled 36 holes in a disc and detect with a optical sensor the rotation. Which means that at maximum speed of the wheel, our optical Sensor will output a TTL Signal with a frequency of 3200 Hz. (3200 times high and low a second).
The question: Is NI MyDAQ able to measure with a digital input (Or the counter) such a high frequency. Our target is to measure the speed of the wheel and to draw a graph over time.
Thanx very much for replies and your help!
WhiteCloud
Active Participant
Henrik_Volkers
Re: Maximum frequency for the Digital Counter Input
RTFM
Spec, page 40:  Maximum couting freq: 1MS/s   :smileywink:
Greetings from Germany
Henrik
LV since v3.1
Member
WhiteCloud
Hi Henrik,
tanx very much for your reply and help, in fact you are right and the DAQ had no problem with this "high" frequency (By the time we set up our sensoro with DAQ)!
Greetings back from Germany (Hätt ich mir mein schlechtes englisch ja sparen können... :-)
WhiteCloud
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
