We are having hardware STM32F103RE which gives the output accelerometer gyrometer and magnetometer .
I want to integrate this hardware with Embedded arm S/W in labview and acquire its data.
With help of this reference manual http://www.ni.com/white-paper/7120/en#toc3 I found that i my pc RTX_Conf*.c file is not there. so i skipped to chapter 4
While continuing with this process in the keil software at Debug tab i cant find ULINK ARM DEBUGGER to select , On going further i can find some files to load as mentioned in the chapter 4
