Hi Brandon,
Try a fresh installation, follow this guide and reinstall form the dvds. I would recommend to copy the files to the hard drive and run the exe file from there.
The blue light should stay on, like mentioned at the user guide. Take a look at the device manager and search for yellow question or exclamation marks. try to follow this recommendations or simply delete the entry and reboot. That should force windows to recognize the device again, when the software is ok. Good luck.
Alejandro | Applications Engineer | National Instruments
