NI Home
Cart Cart | Help
You are here:
Reply
Member
Mic_Lin
I can't connect the USRP2 with my computer.
Hi!
I want to connect the Ettus Research USRP2 with my computer using the NI-USRP Utilities application.
But I encounter some promble, the NI-USRP Utilities application can't find the device.
I refer to the teaching of this web site. ( http://www.ni.com/pdf/manuals/375717a.pdf )
1. Installing the software:
Labview 2011
Labview Modulation Toolkit 4.3.2,
Labview Digital Filter Design Toolkit,
Labview MathScript RT Module,
and NI-USRP 1.0.
2. Default IP Address:
Host Ethernet Interface IP Address 192.168.10.1
Host Ethernet Interface Subnet Mask 255.255.255.0
Disable the firewall settings
The NI-USRP Configuration Utility can not find the USRP2.
And then I try to use the "uhd_find_devices" for finding the USRP2,
the result is:
C:\Program Files\National Instruments\NI-USRP\utilities>uhd_find_devices
Win32; Microsoft Visual C++ version 9.0; Boost_104400; UHD_003.002.003-vendor
No UHD Devices Found
Thank you!
Active Participant
Sarah_Y
Re: I can't connect the USRP2 with my computer.
This post was also posted on the USRP discussion forum and has been answered there.  Please refer to this post for the full discussion and resolution:
http://forums.ni.com/t5/USRP-Software-Radio/I-can-t-connect-the-USRP2-with-my-computer/td-p/1863665
Sarah Y
Test Engineer
Ettus Research
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
