NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Manushak
Accepted Solution
How can I see Elvis II boardID
From "NI ELVIS II Pinout Descriptio" I know about
"BoardID<0..7>- These eight lines signify the unique ID of each type of prototyping board by shorting them to VCC or to GROUND."
In my own board I have connect 5volt to boardID pinouts, but I dont know how I can measure my boardID value.
Member
SunainaK
Re: How can I see Elvis II boardID
Hi Manushak,
BoardID's are only for third party boards and not NI prototyping boards. Are you developing your own board?
Sunaina K.
Member
Manushak
Hi Sunaina.
Yes, I have developed my own board.
Member
SunainaK
Hi Manushak,
You would need to get in touch with your Technical Sales Representative by calling 1-888-280-7645.
Sunaina K.
Member
Manushak
Hi Sunaina
My Elvis II and my own board don't have technical problems.
I want to measure boardID value in my VI, without using digital channels, I can't find function or DAQ property to measure boardID.
Member
SunainaK
Hi Manushak,
If you call the Technical Sales Representative, they will be able to put you in touch with R&D who will be able to help you to incorporae your custom board with Elvis.You can read the boardID by Dev1/channelName_BoardID, where Dev1 is the Elvis Board.
Sunaina K.
Member uzh
Member
uzh
I had exactly the same question
I tried the above and found that Dev1\_BoardID digital lines work and show the ID
Member
Manushak
tanks, finally I can read the BoardID of my board
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
