11-17-2011 01:23 AM
11-17-2011 09:02 AM
es esta ventana..
dice que la linea que estoy utilizando ya esta reservada pra otra tarea
gracias
11-17-2011 05:46 PM
Hola Martin_E,
Es precisamente lo que te comentaba. El error de recursos compartidos se debe a que en el modo automático estás reservando el puerto digital de la myDAQ. Por lo tanto, si no lo has liberado, el modo manual no puede reservar el puerto para cambiar el estado de alguna línea digital. Con esto me refiero a que no puedes tener 2 DAQ Assistant corriendo al mismo tiempo si ambos ocupan el mismo recurso, en este caso el puerto digital de la NI myDAQ. Tendrías que detener la tarea de un DAQ Assistant para que liberes el recurso y el otro pueda correr. Pero esto tendrías que hacerlo cada vez que quieras cambiar de modo automático a manual y viceversa.
Saludos,
Héctor
05-15-2012 12:04 PM
I have the same problem on a new install of Labview 2011.
I purposely installed NI Elvis after and then the drivers but still have no initialize vi.
How or what is the procedures to uninstall and install drivers?
05-17-2012 11:36 AM
Hi ez1,
You can uninstall the drivers from Start >> Control Panel >> Programs and Features. You need to select National Instruments Software and click the Uninstall/Change button. A new window appears that contains all the software from NI that you have installed on your PC. Then you can select the driver you want to uninstall and select Remove. Once it has finished Removing the driver, it will prompt you to restart your PC. Once the PC boots up again you can begin the installation of the same driver. Let me know if you have any problems with this procedure. I recommend that first you check the previous posts, because NI ELVIS II drivers does not include the same VIs that came with NI ELVIS I.
Cheers
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
