NI Home
Cart Cart | Help
You are here:
Reply
Member
Arturo_izq
Elvis DIO "NI ELVIS DIO - close.vi", "NI ELVIS DIO - write.vi", "NI ELVIS - initialize.vi" not found on NI Elvis II
Hi.
I hope somebody can help me.
I'm trying to use Elvis II, but I cannot see the "NI ELVIS DIO - close.vi", "NI ELVIS DIO - write.vi", "NI ELVIS - initialize.vi"  libraries. The ELVIS board is detected by the MAX applictation and I can see the Measurement I/O pallete on Labview, but I cannot see the Instrumets I/O for ELVIS. I´m using Labview 2009 SP1 and 4.2.3 drivers.
Also I can use it directly from the ElVIS Instrument Launcher.
Thanks in advance.
Best regards.
Arturo.
Active Participant
Hector_ZRJ
Re: Elvis DIO "NI ELVIS DIO - close.vi", "NI ELVIS DIO - write.vi", "NI ELVIS - initialize.vi" not found on NI Elvis II
Hi Arturo_izq,
        This happens most of the times when you install NI ELVIS drivers before installing LabVIEW, so LabVIEW does not recognize the drivers from NI ELVIS and this is the reason you do not have the NI ELVIS palette available. The solution is to uninstall NI ELVIS drivers, and reinstall them so that LabVIEW can include the palette. I hope this helps, so let me know if this worked out for you.
Hector Rojas
Member
Arturo_izq
Hi.
I've solved it as rewriting the code.
It seems that "NI ELVIS DIO - close.vi", "NI ELVIS DIO - write.vi" and "NI ELVIS - initialize.vi" are not found on NI Elvis II package, they are only for NI ELVIS I  (In two different machines with ELVIS II happens the same behavior).
I've used instead the NI ELVISmx Pallete located in Measurement I/O
Thank you anyway Hector.
Active Participant
Hector_ZRJ
Hi Arturo_izq,
        I'm glad to hear you solved the problem. Let me know if there's anything else I can help you with.
Héctor Rojas
Member
Martín_E
hola saludos...bueno en mi labview 2010 no encuentro estos archivos...
dond los busco para que se cargen...
Mil gracias.
Active Participant
Hector_ZRJ
Hola Martin_E,
         ¿Que versión de ELVIS es la que estás utilizando, I o II? Te lo pregunto porque, tal como comentaron anteriormente, estas funciones no están en el driver de ELVISmx que viene con NI ELVIS II. Por tal motivo, tienes que sustituirlas por funciones que vengan en la paleta de NI ELVISmx, localizada en la categoría de Measurement I/O dentro de la paleta de Funciones. Espero que te sirva la información.
Saludos,
Héctor
Member
Martín_E
lo resolvi con la paleta de funciones...gracias
pero ahora tengo otro problema......estoy utilizando la ni mydaq y mi programa controla los puertos digitales  de forma automatica.
y ahora que agrege de forma manual con la ni elvismx sale error.
------Mi objetivo es prender focos de forma automatica y al mismo tiempo poder controlarlos de forma manual
de antemano gracias
Active Participant
Hector_ZRJ
Hola Martin_E,
       ¿A qué te refieres cuando dices que los controlas de forma automática? Asumo que por forma manual te refieres a VIs de bajo nivel de la paleta de ELVISmx que tienes disponible en la paleta de Funciones. ¿Qué código de error es el que te marca LabVIEW? En el caso de la NI myDAQ, ¿has intentado utilizar los VIs de DAQmx que se encuentran en Functions >> Measurement I/O >> DAQmx? Si utilizas estos VIs no deberías de tener ningún problema para utilizar los puertos digitales de tu tarjeta NI myDAQ. Puedes incluso revisar ejemplos en LabVIEW Examples que puedes utilizar como base para tu programa.
Saludos,
Héctor
Member
Martín_E
saludos mi buen amigo..
estoy utilizando los 8 puertos digitales  de salida de la mydaq, estos puertos se encienden automaticamente segun el ritmo de la musica.
ahora con el ni-elvismx pude puedo encender de forma manual cada puerto.
realize un programa
1.- en la forma automatica se encienden los puertos de forma aleatoria.
2.- quiero al mismo tiempo tener un control manual. endender o apagar cada puerto..
ejemplo: si en la forma automatica se activan los puertos 1, 2, 3,4 ,5 ..de forma manual quiero apagar el puerto 3  y encender el puerto 7
gracias
Active Participant
Hector_ZRJ
Hola Martin_E,
         ¿Podrías decirme qué error es el que te marca en LabVIEW? Lo más probable es que te marque un error de recursos compartidos, porque en el modo automático estás reservando el puerto digital de la myDAQ. Por lo tanto, si no lo has liberado, el modo manual no puede reservar el puerto para cambiar el estado de alguna línea digital. Pero para darte una solución, te agredecería mucho si puedes mandarme el error que te manda LabVIEW.
Saludos,
Héctor
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
