03-27-2013 01:27 PM
Hi
I am planning on using the camera's trigger for send LVTTL volt but after run the program I see the error that attach here.
I need help outputing a LVTTL signal from the trigger to my camera(Apogee camera). Any help would be greatly appreciated.
04-03-2013 12:00 PM
Hi vsa.
Could you attach a screenshot of the error? It is often helpful to se the message that LabVIEW sends along with the error code to determine where and why you are getting the error on your VI.
Regards
04-03-2013 12:09 PM
Hi francisco
yes, thanks
04-03-2013 05:55 PM
Hi vsa.
The error that you are getting is due a generic error that is returned by the library and not directly by LabVIEW. This can be a lot of possibilities such as bad syntax or incorrect values. I was reading at the library documentation and I believe it might be an error due to duration of the "Expose" method. We could get the maximum expose duration with the property "Max Exposure" which is explained on the document.
I am attaching the documentation in case you don't have it.
Regards
http://www.ccd.com/pdf/AltaDevApi.pdf
04-10-2013 06:12 PM
Hi
yes, you are right, my error is not directly by LabVIEW but I do not know how can I change my code to getting true.
I read this document.I like that my camera supported all of the valuse of Exposure.
can you help me please?
Best regards
