the VI closed the connection : error 1074360302 at property node(arg 1)
hi!
I'm trying to running a code which apply the control of my myRIO through a VI on my host computer. A video stream of data is also going to be send from myRIO to the Host Computer VI. However, I am getting the "Host Computer VI" closed the connection. I have no idea why.
And at the Host Computer keep giving out error 1074360302 occured at Property Node (arg 1) in myRIO vi.
I would be glad if someone could help me.
Thank you.
(5,765 Views)
Hi e_pah,
Thanks for your post, how are you connecting the myRIO?
Ingram
(5,724 Views)
I'm connecting it through WiFi.
Thank you.
Regards.
(5,696 Views)
Hi e_pah,
Thanks for your response, what sort of camera are you using? This error has been previously seen with a Stingray camera when the IMAQ drivers aren't quite up to date.
So firstly, we need to make sure the IMAQ drivers are updated.
Further questions regarding your application:
Did this VI ever run?
Does this error occur everytime the VI is run?
What is the the property node doing?
Many thanks
Ingram
(5,659 Views)
