synchronize AI and AO with myDaq
I am looking to use a myDAQ device to synchronize the Analog Input and Analog Output. I was trying to use AI0 and AO0. I wanted to create a signal every 5 seconds and have that same signal read by the myDAQ, I am eventually going to share this signal with another system so this is mostly for test purposes for now.
The VI I am currently using is attached below. The VI was taken from someone using a USB 6218 which supported sample clock sharing but I don't know how to do this with the myDAQ. I have seen mixed opinions on this matter on other discussions, some saying that sample clock sharing is possible, and others saying that the myDAQ doesn't support it.
I am using the myDAQ with labview.
(4,985 Views)
Hello jepsenkc,
Please check the following forum:
http://forums.ni.com/t5/LabVIEW/generating-clock-using-mydaq/td-p/3111171
Warm Regards,
Sigi D.
Application Engineer
"everything is achieveable through technology'
(4,925 Views)
