store template image in myrio for pattern matching digital image processing
i am working on digital image processing using myrio . i have done pattern matching technique in laptop successfully . now i want to do this on myrio . for this i sucessfully acquire image from myrio
but problem is how i can store template image in myrio for matching purpose? ,
(matching acquired image with template image)
(2,889 Views)
One option to transfer a file to the myRIO is WebDAV. I have included a link below on how to get started with WebDAV. The myRIO uses a Linux OS so you will need to reference the Linux section of the document.
In general: once you have WebDAV set up, you can transfer the file to your myRIO, and then point to the directory it is located to pull into your LabVIEW program and use the image file as your template image.
Using WebDAV to Transfer Files to Your Real-Time Target
http://digital.ni.com/public.nsf/allkb/4EBE45E8A816B19386257B6C0071D025
Matt G.
Product Manager
(2,839 Views)
