09-23-2014 05:15 PM - edited 09-23-2014 05:18 PM
I have created a program consisting of a main VI and sub VIs which I need the myrio to run from outside the labview environment in a stand-alone fashion every time the myrio boots up.
I have followed this turotirial: http://zone.ni.com/reference/en-XX/help/370622J-01/lvrthowto/rt_building_rt_app/#outside
and build a standalone real time application to be deployed from outside the labview development environment. I have then used NI MAX to install it on the myrio.
The first time the myrio reboots the VI starts automatically and runs perfectly, I then use the on board button programmed to stop the VI, no problems at all. However from this point on when I do either a hard reset of the myrio or reset it through NI MAX it no longer runs my VIs at boot.
Can anyone tell me why this is happening?
-Mike
myrio 1900
labview 2013 + myrio module
windows 7 professional
09-24-2014 12:51 AM
problem solved - didnt set as startup.
