puzzles when using 9605?7811R?
I have one machine manufactured by OEM with NI cards and PXI controller. I can see the 7811R module and cables from it in front of the box,but the 7811R can not be found by MAX. even the examples from "Labview help " of 7811R can not work ,showing a yellow triangle and a"!". So I suspect that there may be a lack of Labview FPGA module or RIO driver ,but in fact this machine can indeed work properly by the project offered by the OEM. Meanwhile , I found sb9605 by MAX, a romote device. but ,where is it ??? I searched through this machine for it ,but can not found it !!
Message 1 of 1
(3,910 Views)
