pressure from velocity conversion in labview
I am currently working on a project with myrio labview and I am using some 8 piezoelectric sensors.I just need to know the conversion of voltage to pressure.My sensor output will be voltage which is fed to the myrio .I need the results in terms of pressure.How to do the conversion?
(2,809 Views)
Hi Gayu,
The conversion formula you will use depends on the type of sensor you are using, and will be provided by the sensor manufacturer. A typical conversion formula will be a function of the excitation voltage, full scale capacity of the sensor, and a calibration factor.
In order to convert the voltage into pressure Refer to the below formula
For example, a pressure transducer with a full scale capacity of 10,000 PSI and a calibration factor of 3mv/V and given an excitation voltage of 10V DC produces a measured voltage of 15 mV, the measured pressure would be 5000 PSI.
Hope this helps
Kudos are welcome Smiley Happy
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(2,774 Views)
