niusrp in labview rt
Hello.
I'm interested in putting niusrp libaries to the myRio. Is this something that could be possible?  Is this something you are working towards?
Being able to run niusrp in labview RT would be handy.
v/r
Chris
(5,020 Views)
Hello Chris,
Are you talking about a DLL when you refer to library?  Have you tried importing the USRP RIO DLL to your myRio?  I've included the NI USRP Readme 14.0 below for you to see where the DLL is located:
http://www.ni.com/pdf/manuals/374760a.html
Also, you might want to consider LabVIEW Communications:
http://www.ni.com/labview-communications/usrp-rio/
Jonathan R.
(4,998 Views)
Sorry for the delay. Busy times.
What I want to do is control a b210 on a myRIO. I'm reading through the links you provided and will provide feedback.
1:45 pm est 12-5-2015 edit 1.
Hi, I'm now looking into if you guys provide the means to compile nisurp as a shared object.
http://forums.ni.com/t5/LabVIEW/MyRio-using-shared-Library-dll/td-p/2816390
(4,908 Views)
I can't find the source to try and compile the so. I don't think I can use the dll on the myRio.
 please advise
(4,872 Views)
