12-11-2013 09:15 PM
Hi, I got the myRIO last week, and it's able to connect to my computer by using USB port or WIFI. But yesterday when i'm connecting myRIO project to my computer, it display " Access denied: This host computer's IP address is not on the target's allowable access list.", then neither USB nor WIFI connecting can work. I have tried reinstalling myRIO and reset my IP, but none of them is useful. It seems that there is a same problem in cRIO before, but that solution is not avalible for myRIO. Please help me, thanks.
12-12-2013 09:58 AM - edited 12-12-2013 09:59 AM
Hey,
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
12-13-2013 07:50 AM
Dear Sam K:
I have use one of my friend's computer, it can connect at beginning, but failed just yesterday, the same problem like which on my computer.
My computer IP is 140.116.85.155
and below are the picture of myRIO's IP
and this one is the user access list
it seems everything is okay, but myRIO just can't connect at all
12-17-2013 11:28 AM
Hey 511045,
Have you tried adding your computers IP address to the list (* should include it, but it is worth trying). Does this problem persist if you reformat and reinstall the recommended software set on the myRIO?
Thanks!
-Sam K
12-17-2013 11:55 PM
Hi 511045,
Could you format your myRIO and then add software again please (Either under MAX or use myRIO wizard to reinstall it). BTW, what's your driver version of myRIO? 13.0.0 or 13.0.1?
Brad
12-18-2013 08:05 AM
I finally solved this problem, it seems that formating the disk work out, and I can move on to my final project.
Thanks to all of you, you really help me a lot.
02-17-2014 10:28 AM
Hello, it's interesting also a problem when trying to connect to the device, a delay caused by the quality of the WIFI signal, after this happened another problem when I make a Myrio FPGA project project could not be compiled and downloaded to the target is generated , anyone know why this happens
06-05-2014 03:24 PM
my myrio requirement a password and login to format
what can I do?
06-05-2014 04:14 PM
Did you change the default password? Else try admin with a blank password.
06-06-2014 11:41 AM
ok, formated.. but my problem continue
