03-02-2016 04:26 AM
Hello fellows,
I was wondering if there is a way to use NI myRIO as a standalone board with no PC, such that LabVIEW is installed on an OS and the pogram runs on it.
I tried to read about the embedded NI Linux Real-time OS but there are no clear documentation of how to use it.
Solved! Go to Solution.
03-02-2016 07:26 AM
Yes, from your LabVIEW project you can create a 'Real Time Executable' under 'build specifications' on the myRIO target which you can deploy to the myRIO and set it to run automatically when the myRIO boots up. Obviously it won't have any sort of user interface so you will need to consider how you will control/interact with it (or maybe just log data to file).
There's a YouTube video that covers the process here: https://www.youtube.com/watch?v=JXoJECRS-eo
There's also a guide here: http://zone.ni.com/reference/en-XX/help/370622K-01/lvrthowto/rt_building_rt_app/
04-20-2016 12:22 AM
Hi T2
Deploy your LV code in myRIO and unplug, it will run without any problem. if you want to make a application, right click on build specification and build an Executable(exe) file.
