03-05-2014 06:26 PM
I am new to the MyRIO system, and have a quick question about analog data acquisition. Can the DAQmx VIs be used with the MyRIO? In my experience, when I use the DAQassitant to try to select an input device, the MyRIO does not show up.
Thank you very much,
Sean
03-06-2014 08:11 AM
Hi seanmw,
DAQmx VIs will not work for myRIO because it runs off the NI-RIO Driver. There is a myRIO Module that comes with myRIO. Here are pages to the module and the VIs that you will be able to utilize:
http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myriohelp/
http://zone.ni.com/reference/en-XX/help/373925A-01/myrioreference/myrioreference/
03-06-2014 12:53 PM
Thanks for the reply Peter, I apprecaite it.
