06-24-2011 12:45 AM
Para usar la mydaq con multisim para mediciones en tiempo real, ¿se debe "dibujar" el circuito en multisim o sólo utilizaria las herramientas que multisim ofrece para poder vidualizar las mediciones?
06-24-2011 12:49 AM
The question in English is:
To use the mydaq with multisim to real-time measurements, is it necessary to "draw"the circuit in multisim or only use the tools multisim offers to display themeasurements?
06-28-2011 03:37 PM
Hola,
Puedes simplemente utilizar los intrumentos de NI ELVISmx dentro de Multisim para realizar mediciones del circuito real, sin embargo, si quieres comparar resultados reales vs. la simulación, entonces debes también capturar el circuito en Multisim.
Saludos,
07-23-2011 02:36 PM
What is the answer in English?
07-25-2011 08:22 AM
Here it is:
If you want to take measurements from a real circuit you can simply use the NI ELVISmx instruments in Multisim, however, if you want to compare real vs. simulated results you must capture the circuit in Multisim (File>>NI myDAQ Design).
03-20-2012 02:55 AM
Buon giorno e ciao a tutti, avrei un problema con multisim un po oscuro, volevo sapere dove trovare la voce NI myDAQ Design, nel menù questa voce non esiste, sapete risolvere questa problema, la mia versione di Multisim e la 12
03-20-2012 07:13 PM
Hola SIQ,
Lo siento, no hablo italiano, pero te recomiendo publicar tu foro en la siguiente página: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
Ciao SIQ,
Mi dispiace, non parlo italiano, ma vi consiglio di inviare il vostro forum alla pagina seguente: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
Hi SIQ,
I am sorry I don´t speak italian; however, you can post your forum question in the next link: http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/bd-p/7170
