08-21-2013 08:39 AM
08-21-2013 09:36 AM
Hello abenigma,
I am not very familiar with the vernier hand dynamometer sensor, but if it uses the same Analog Proto Board Connector the connection should look something like this:
Connect the following pins to wire the connector:
AI0+ to SIG1 of the Analog Proto Board Connector
+5V DC power supply to 5V of the Analog Proto Board Connector
GROUND power supply to GND of the Analog Proto Board Connector
AI0- to GND of the Analog Proto Board Connector
Give it a try.
~ Sandra
08-21-2013 10:50 AM
