10-04-2013 01:24 PM
Hi. When I open the Daq Assistant on Lab View it gives me a "No supported devices found" message, the labView works just fine but it does not recognized the myDaq. And before It did worked, What can I do?
10-05-2013 08:45 PM
Have you installed ELVISmx driver, http://joule.ni.com/nidu/cds/view/p/id/4316/lang/en, which is needed for myDAQ?
10-06-2013 06:26 PM
I did installed the driver and it worked for a while, however, when i opened it the day after it did not recognized it again.
10-07-2013 07:56 AM
If you are using Measurement & Automation Explorer 5.0 or later, you could try resetting your configuration data by clicking the following menu option. It may solve your issue if MAX has been corrupted. Just a note, resetting your configuration data will clear any saved devices/scales you have.
Also, what operating system are you running?
